Chainbreaker
- 1,839
- 113
- Oregon
That's known as "hunting". That would point more to a governor adjustment/issue. So Ray is right in suggesting that direction....I noticed that the rpm go up and down in a rhythm.
is it possible the springs have aged? That’s all I see that could be wrong. Does anyone know where to buy the governor springs? I looked all over the place.I've been in the governors before, but only with the engine removed. Not sure how well you can see or access things unless you at least remove the radiator and housing. After that removing the front cover is simple. I've seen issues with incorrectly assembled internal linkage and other issues with the fuel rails being bent etc.
Either way, it's pretty easy once you get in there and follow the diagrams in the TM.
Thank You, I didn’t know the terminology. My generator is definitely hunting.That's known as "hunting". That would point more to a governor adjustment/issue. So Ray is right in suggesting that direction.
If thats the avenue you want to go, reach out to Gary Jones @ Diesel Electric Services (reference that you have a military LPW4). https://diesel-electric.usis it possible the springs have aged? That’s all I see that could be wrong. Does anyone know where to buy the governor springs? I looked all over the place.
Also light in the dark!!!thank you!I appreciate all the help from chain breaker, ray 70 and guy, you guys are the reason I come to this forum. Thank you
You are right, when I move the shut off I’m able to make it run like a normal functioning unit.You know.... I wonder if we could be overlooking the obvious?? Is it possible your governor droop adjustment is way off??
Take an look in the TM, it will tell you how to adjust it. There's a plug in the timing gear cover near the governor. You remove the plug and use an allen wrench to adjust the droop. If the adjustment is too sensitive you wind up with constant hunting, too little sensitivity and you end up loosing RPM as the load increases. Before you go further I think we need to rule out the droop adjustment.... which in reality just changes the tension on the springs, so you should be able to compensate for a weak spring ( which I feel is unlikely ) by adjusting the droop.
Start the machine up with the fuel shut off solenoid disconnected.
Then with your hand slowly turn the shut off lever to the left. You will eventually feel it contact the fuel rack and start moving the rack left towards the off position. See if slight pressure against the fuel rack with the shut off lever stops the surging and smoking. If so, I think you may just have a really bad droop adjustment.
The fuel shut off solenoid is not going back and forth like the governor is. Also the throttle leakage is set correctly. Thank you to guyfang for jumping in, your troubleshooting is on another level. What does this tell us guyfang?I haven't jumped in here till now. Just reading the threads.
Is the throttle linkage set right?
Is the L5, Fuel solenoid also moving? Or just the engine hunting, with no movement of the linkage?
I would say Ray's # 31 post is the next step. I thought I would just cover the bases, that up till now haven't been covered.
If fuel pressure to the IP's is good, and the injectors pop off, the L5 is rock steady, linkage is adjusted right, then what do you have left? The governor.
Thanks guy,I would say Ray's # 31 post is the next step. I thought I would just cover the bases, that up till now haven't been covered.
