803a water separator breakthrough!
Buickrat
New Hampshire
Yes, pjwest, that is what I found also. They are sending me one to try, just have to work out the o-ring details.
I'm also going to use a brass fuel shut off instead of the petcock style drain originally in the unit. Will get pics of the setup when it's done.
Thanks!
Buickrat
New Hampshire
Triton, sorry but no. The Dixon part did not fit the wix/napa filter. I am convinced that wix has used some hokey china pipe thread that only works with the POS plastic plug they put in the filter.
All those fittings I bought (threw all the filter out) sit in a dusty and dirty sealed plastic bag on my desk as a daily reminder that I have failed.
I prolly blew 250 bucks in filters and fittings, and am still stuck with pos fram!!#%&@.
uniquify
231
Sioux Falls, SD
Agreed, here's a list of things I've tried unsuccessfully:
1) 1/8"-27 NPT
2) 1/8"-27 NPS
3) 1/8"-28 BSP
4) M10x1.0
5) -3AN O-ring boss (3/8-24 thread)
Of all those, 1/8"-27 NPT was the closest fit, but would only engage about 2 threads. I eventually got fed up with it and just cranked on it until I made it fit.
I'd still like to find something that works, but am running out of options.
Bmxenbrett
30
I have been a diesel mechanic for about 10 yrs. In this time i hardly ever find a real need to use the drain on the bottom of filters. Some dont have it and some its impossible to get to.
csheath
214
FL
Every time I look at the drain hose on mine it's full of mud from dirt dabbers. What's wrong with just draining it in the case or holding a cup under it?
I appreciate the effort you all went to but sometimes these things just don't pan out or justify the time and cost expended. Might want to get an admin to fix the title.
[h=2]803a water separator breakthrough? NOT![/h]
keen
geneva, fl
I decided, against my better judgement, to search out a fram (yeeuuck) p8043....
Well, lo and behold, picked one up at autozone today and removed the petcock drain and presto, 1/4 npt, fits the stock drain perfect.
Sadly this is no longer the case in 2021 - the recent FRAM P8043 I picked up doesn't have a 1/4 npt outlet, it's a knockoff of the baldwin BF5587-D now. I haven't tried to ID the specific thread.
