804A power transfer issue
Guyfang
27,258
Burgkunstadt, Germany
Normally, it is not a failed coil. Its that these things are notable for getting moisture in them, and then they kinda rust up. Mostly easy to correct. If its broke, you can't make it broker.
DBLE
13
Acworth, NH
Good morning Guy,
All the more reason to get this genset under cover. Weather here this morning looks a bit ominous, but the investigation exercise shouldn’t take all that long. I’ll report back.
DBLE
13
Acworth, NH
Good morning Guy,
Guy,
No voltage at X,Y at K1, with Main SW in run position, battle short on, S5 Up, To ensure the contactor was in good shape, I removed it. Was a bit sticky, No sign of any water or rust, contacts needed dressing up. Coil measured 43 ohm. Ran out of daylight, will test coil / contactor with 24 VDC from battery in the Am. ( 24vdc applied across X,Y AT K1) 7-1/2 Control fuse appears to be a re-setable type, doesn't appear to be popped out (tripped) the other 2 fuses are good.
Any thoughts on next steps?
Guyfang
27,258
Have you bench tested the K1? If so, what happened?
If it works, Make sure S5 is wired like this. Then remove wire 140D. Measure from that wire to wire #240A, at the K1. Also remove that wire, so you are only measuring the wire, not the K1. What you get?
