804A with ~52hz and AC undervolt?
Zed254
468
S. Hampton Roads, VA
I'm getting from TM 9-6115-643-24P:
15 PAFZZ PAOZZ 5930-01-368-5160 30554 01-20002 . . SWITCH, ROTARY ..................... 1
Part Target shows your part number, too. https://www.parttarget.com/5930-01-...ption=nsn&originalsearchtext=5930-01-368-5160
Kraus & Naimer make the blue switches with the plastic shafts.....that break easily. I've not been able to cross to an Electro Switch for the 804A but it looks very similar to the 5 position Master Switch for my 803A. Electro Switch makes a much better switch.
Guyfang
27,256
Burgkunstadt, Germany
OK, Here we go.
NSN: 5930-01-498-9903 Part Number: CHR10-57410 This is the first generation switch. Works, but not the best quality. Looks like yours was one of these. Cost $113.
NSN: 5930-01-531-2972 Part Number: 88-22827, 75901Lj, CHR10-C57410FE, DHR10 C57410EF Third version, Much better switch. Cost $36.58 Yes this is from Electro Switch.
NSN: 5930-01-368-5161 Part Number: C10-57410E This is the second generation switch. Works, but not the best. Cost $70.
All of the above fit, and will work. The Producer of the switch, (and here in Germany is considered a VERY good company) is Kraus & Naimer.
I would plug all the part numbers and NSN's into my search engine, If price is your concern. If a quality switch is what you want, CHR10-C57410FE, DHR10 C57410EF would be my first choice.
