80mph Speedo harness mount locations
HmmwvTim
95
IL
Hello all,
i am trying to figure out how to mount some harness mounts for the 80mph speedo. All I have is this from the TM
is there another TM that provides details? I assume part 10 goes inside the dash to offset the resistor so the wires can fit better. I al looking for exact locations for parts 2 and 4.
any help or photos would be appreciated.
Action
1,552
East Tennessee
TMB 9-2320-335-13&p was a technical bulletin issued when the REV came out. It was later meged into TM 9-2320-387-24p, TM 9-2320-387-24-1, TM 9-2320-387-24-2, and TM 9-2320-387-10.
If you are using TB 9-2320-335-13&p, look for the section titled "Speedometer Harness Assembly Replacement". It has detailed pics of the nuts, bolts, and zip ties and where they go.
Your piece of paper is from the parts book / section of TB. The maintenance books *section of TB) shows how to remove and install everything.
HmmwvTim
95
IL
Thanks.
I’ve been looking all over and it seems the versions of what you posted that I have does not contain “Speedometer Harness Assembly Replacement” in it. Can you send a direct link and page number of where you saw it? That might help me out. Thanks again~
Action
1,552
East Tennessee
Thanks.
Do a web search for "pdf tb 9-2320-335-13&p"
left click (with the mouse) on one of the links to open the manual
left click on the magnifying glass to perform a search in the document
type "speedometer harness assembly replacement" in the search box
hit enter
you will now be on the first page of the procedure
there is only one release of TB 9-2320-335-13&p, so there is no chance of getting the wrong version.
the most recent update to tm 9-2320-387-xx-x's that include the above tb are not as easy to find.
HmmwvTim
95
IL
hit enter
that weird… that was the first document I looked at and search found Nothing. It worked when I tried it again. Page 144. Thanks
