813A1 Primer pump fuel line fitting
WWIILBird
14
Northern NJ
Can somone tell me if the primer pump fuel line fitting threaded into the bottom of the fuel pump (Cummins) are special fittings or over the counter part. From the attached drawing I think it's parts 10 & 11 that I need? I tried putting in a fitting which I believe was 1/4 inch with a compression fitting on one end but it wasn't takng real well so I stopped. Also if over the counter (i.e. Napa) could you tell me part numbers or if specialty part recommend a source to purchase from? Thanks
