- 12,195
- 327
- 0
- gainesville, ga.
I would NOT bump the fuel TILL you had a WORKING pyo, the 250 DOES NOT have piston coolers, it would be a shame to cook a piston.
Dont know the RPMs as the Tach cable is broke, ordering one, but needing one that is longer than stock for the bigger intake.. found out yesterday that an M35a2 or 3 is about 6" longer with the same ends so that should work,,,,Good to hear that the engine upgrades have helped a lot.
What are your rpm's when the engine feels like it defuels?
If your looking for a used one let me knowDont know the RPMs as the Tach cable is broke, ordering one, but needing one that is longer than stock for the bigger intake.. found out yesterday that an M35a2 or 3 is about 6" longer with the same ends so that should work,,,,
Thanks,,, Ill look into this when the tach cable gets here. Right now looking at either Eriks Surplus or Army 6x6, Due to my geographic location .....(BFE) Andy at Army is closest, but I need a couple other things too,,, Namely Im trying to get the Runnins Lights on with the headlights, and Erik sells an adapter plug that does the splice for you, Pretty expensive but no splicing required all plug and play at the back of the light switch.I would think either de-fueling is an issue or maybe fuel supply is restricted pre pump, now that you have the dual lines and the turbo the stock supply line might be partially restricted and where the stock motor could live with it you may be requiring more fuel then can pass through now. I have also heard of a case where the dual line mod cause the motor to start de-fueling earlier and needed the governor tweaked to regain the rpm.
Those washers that were left out when you swapped buttons will adjust that.got the new tach cable in last nite, and it is taching out at 1800,,,, SO..... How do I get it back to 2300rpm.??????
Yes, that would definitely cause that issue! You can change buttons but keep the same number (or even add 1 or 2) as the pump that was on the engine had.Those washers that were left out when you swapped buttons will adjust that.
