DaveP
- 3
- 38
compareison
I see your getting the 11x20's on, hope it all works out well!DaveP said:compareison
dont use blocking. use 8 ft long lumber. I use two 4x4x8'sRattlehead said:How about blocking under the landing gear when you set it down? The first time with a trailer would be difficult. I was actually thinking on a trailer recovery that you could set the front of the trailer on the front bumper(assuming its a fairly light, unloaded trailer), retract the landing gear, then block it and raise it up higher. You are forever having to block it when you unload a trailer though.jwaller said:well I too thought about it a long time ago but I need the ramps to help get under trailers bc of the huge height the truck has. and if you move the plate back to have to mod the ramps and I dont want to do that bc you start down a road of changing things and I want it to look original.
All the more reason to add a power divider.Rattlehead said:All good tips, thanks.
DaveP, you're gonna have some major axle wrap-up with that tire setup!![]()
