- 455
- 1,084
- 93
- Wapakoneta, Ohio
looking for the size of the electronic governor rod heim joints so that i can make my own as i can not find a used one to install.
3120-01-477-2736 part number BR100. i have a parts wanted ad up now that i found the part numbers might get a reply , but if i have just this part i can make the rest.give me a part number, and maybe I can get that for you.
Thread Class | 3B | |
THREAD DIRECTION | RIGHT-HAND | |
SHANK STYLE | INTERNALLY THREADED W/HEXAGON END AND INSPECTION HOLE | |
OVERALL LENGTH | 1 687/1000 INCHES NOMINAL | |
BORE DIAMETER | 0 499/2000 INCHES MINIMUM AND 503/2000 INCHES MAXIMUM | |
LUBRICATION MATERIAL | LUBRICATING OIL | |
OUTER MEMBER OUTSIDE DIAMETER | 0 3/4 INCHES NOMINAL | |
BORE CENTER TO SHANK END DISTANCE | 1 39/125 INCHES NOMINAL | |
OUTER MEMBER WIDTH | 0 69/250 INCHES MINIMUM AND 143/500 INCHES MAXIMUM | |
INNER MEMBER WIDTH | 0 37/100 INCHES MINIMUM AND 3/8 INCHES MAXIMUM | |
SHANK THREAD LENGTH | 0 3/4 INCHES NOMINAL | |
INSPECTION HOLE CENTER TO END DISTANCE | 0 307/1000 INCHES MINIMUM AND 317/1000 INCHES MAXIMUM | |
SHANK WIDTH ACROSS WRENCH FLATS | 0 117/250 INCHES NOMINAL | |
STATIC RADIAL LOAD RATING | 1550 POUNDS | |
THREAD DIAMETER | 0 1/4 INCHES NOMINAL | |
THREAD QUANTITY PER INCH | 28 | |
HARDNESS RATING | 60 ROCKWELL C MINIMUM INNER MEMBER | |
MATERIAL | STEEL OVERALL | |
MATERIAL DOCUMENT AND CLASSIFICATION | 3055470-1111 MFR REF ALL MATERIAL RESPONSES OVERALL | |
SURFACE TREATMENT | CADMIUM ROD END BODY | |
SURFACE TREATMENT DOCUMENT AND CLASSIFICATION | QQ-P-416,TY 1,CL 2 FED SPEC SINGLE TREATMENT RESPONSE ROD END BODY | |
STYLE DESIGNATOR | BALL TYPE | |
THREAD SERIES DESIGNATOR | UNF |
Thanks Guy just what i needed to get this thing going.I THINK, but am not 100% sure, but THINK this will also fit. Below is the tech data for the part.
3120-00-106-8645
70-1111
Thread Class 3B THREAD DIRECTION RIGHT-HAND SHANK STYLE INTERNALLY THREADED W/HEXAGON END AND INSPECTION HOLE OVERALL LENGTH 1 687/1000 INCHES NOMINAL BORE DIAMETER 0 499/2000 INCHES MINIMUM AND 503/2000 INCHES MAXIMUM LUBRICATION MATERIAL LUBRICATING OIL OUTER MEMBER OUTSIDE DIAMETER 0 3/4 INCHES NOMINAL BORE CENTER TO SHANK END DISTANCE 1 39/125 INCHES NOMINAL OUTER MEMBER WIDTH 0 69/250 INCHES MINIMUM AND 143/500 INCHES MAXIMUM INNER MEMBER WIDTH 0 37/100 INCHES MINIMUM AND 3/8 INCHES MAXIMUM SHANK THREAD LENGTH 0 3/4 INCHES NOMINAL INSPECTION HOLE CENTER TO END DISTANCE 0 307/1000 INCHES MINIMUM AND 317/1000 INCHES MAXIMUM SHANK WIDTH ACROSS WRENCH FLATS 0 117/250 INCHES NOMINAL STATIC RADIAL LOAD RATING 1550 POUNDS THREAD DIAMETER 0 1/4 INCHES NOMINAL THREAD QUANTITY PER INCH 28 HARDNESS RATING 60 ROCKWELL C MINIMUM INNER MEMBER MATERIAL STEEL OVERALL MATERIAL DOCUMENT AND CLASSIFICATION 3055470-1111 MFR REF ALL MATERIAL RESPONSES OVERALL SURFACE TREATMENT CADMIUM ROD END BODY SURFACE TREATMENT DOCUMENT AND CLASSIFICATION QQ-P-416,TY 1,CL 2 FED SPEC SINGLE TREATMENT RESPONSE ROD END BODY STYLE DESIGNATOR BALL TYPE THREAD SERIES DESIGNATOR UNF
