831a electronic governor rod
Guyfang
27,222
Burgkunstadt, Germany
I THINK, but am not 100% sure, but THINK this will also fit. Below is the tech data for the part.
3120-00-106-8645
70-1111
Thread Class3B
THREAD DIRECTIONRIGHT-HAND
SHANK STYLEINTERNALLY THREADED W/HEXAGON END AND INSPECTION HOLE
OVERALL LENGTH1 687/1000 INCHES NOMINAL
BORE DIAMETER0 499/2000 INCHES MINIMUM AND 503/2000 INCHES MAXIMUM
LUBRICATION MATERIALLUBRICATING OIL
OUTER MEMBER OUTSIDE DIAMETER0 3/4 INCHES NOMINAL
BORE CENTER TO SHANK END DISTANCE1 39/125 INCHES NOMINAL
OUTER MEMBER WIDTH0 69/250 INCHES MINIMUM AND 143/500 INCHES MAXIMUM
INNER MEMBER WIDTH0 37/100 INCHES MINIMUM AND 3/8 INCHES MAXIMUM
SHANK THREAD LENGTH0 3/4 INCHES NOMINAL
INSPECTION HOLE CENTER TO END DISTANCE0 307/1000 INCHES MINIMUM AND 317/1000 INCHES MAXIMUM
SHANK WIDTH ACROSS WRENCH FLATS0 117/250 INCHES NOMINAL
STATIC RADIAL LOAD RATING1550 POUNDS
THREAD DIAMETER0 1/4 INCHES NOMINAL
THREAD QUANTITY PER INCH28
HARDNESS RATING60 ROCKWELL C MINIMUM INNER MEMBER
MATERIALSTEEL OVERALL
MATERIAL DOCUMENT AND CLASSIFICATION3055470-1111 MFR REF ALL MATERIAL RESPONSES OVERALL
SURFACE TREATMENTCADMIUM ROD END BODY
SURFACE TREATMENT DOCUMENT AND CLASSIFICATIONQQ-P-416,TY 1,CL 2 FED SPEC SINGLE TREATMENT RESPONSE ROD END BODY
STYLE DESIGNATORBALL TYPE
THREAD SERIES DESIGNATORUNF
FarmingSmallKubota
1,393
Wapakoneta, Ohio
3120-00-106-8645
70-1111
Thread Class3B
Thanks Guy just what i needed to get this thing going.
