Ghost70403
- 0
- 1
- Hammond, La
Recently acquired 2 831A's and set about getting them running. Started both without too much trouble, but one of them has a fault indicator that will not reset. All lights are lit, including the battle short with the switch off. Would not reset, and I traced out the wiring to test continuity, with everything checking out. I swapped out the panel from the other generator to it and it works fine. TRC panel pulled had something fall out when removed. My question is if anyone knows where I can find a replacement part for the TRC Fault Indicator. Appreciate any tips and insight! Thanks in advance!
- Don
- Don
