dmc-4359
- 1
- 18
- Chapin, SC
The delivery may not have suited, but the push button glow plug bit would be a pretty serious diagnostic tool as far as determing where your issue lies. It needn't be a permanent thing, nor even something mounted in the dash if you just need to test a cold engine to see if manually cycling the glow plugs will get it to fire or not. If not, then you know the issue must lie within the resistors or the plugs themselves otherwise, you know that the issue is in the controller or between it and the relay.
On my m1009, a six second shot of glow plugs and about two seconds of cranking are all that are needed to get the engine running. I have new Wellman's just like you and this is what kind of cold starting you should expect from your truck.
