86 1009 Lighting Issues
Chevybrit
Northern Pasquotank NC
Hey All
Finally got a 1009, need an inspection and have problems with wiring! The running lights at the front appear to have issues with the bulb holders
amongst indicator issues at the rear..everything works as it should until the headlamps are on then stop/indicators dont
Q. Are the front lamps Halogen as standard?
Q. There has been some overheating damage to the fuse board inside the engine compartment
Q. Is there a proper wiring diagram for the 1009 on the forum .. the maintenance TM has a minimal electrical section
Many Thanks
Chevybrit
Ive swapped out some of the lamp holders in the rear and in the side markers which seemed to be intermittent .. i also found the stop lamp fuse had been changed to a 30A from 10A
When i study the wiring diagram to look for a short somewhere ive traced the orange and blk/wht from the stop lamp switch to something labelled 'lighting cont SW' what is this and where
do i find it physically on the truck ??
Chevybrit
problem solved ... the 10 pin connector had been forced togther and the last two pins (brake and tail light) were squashed together ... it must have blown the brake fuse
because the prev owner had replaced it with a 30A from 10A.... it must have gottten extra hot and fused the plastic shroud around it.
i snipped off the wht and green wires and connected them seperately outside of the 10 pin strip connector with a two pin block and all is good again [thumbzup]
