86 m1009 left front noise
Riden8ked
19
Ct
Ever since i bought my m1009 after drive for a little while, i have a chafing sound that sounds like its coming from the the left front. The longer i drive the louder it gets. Ive rebuilt my hubs when i changed all the ball joints, still getting the sound. I cant pinpoint the sounds. I check the hubs and wheels and they are not hot to the touch after driving. It sounds like a dust shield it rubbing but i cant replicate the sound on stands. I'll see if i can get a video up. Until then any input or suggestions gents?
Squibbly
1,030
South Carolina
Does it get faster and slower with speed? Or constant until you stop?
Does it happen at a certain speed?
cucvrus
9,775
Jonestown Pennsylvania
I recommend you remove the axle shafts and drive shaft from the front axle. Reassemble everything and see if the sound goes away. I mean at least if you take it down that far you are bound to find something. And if not reassemble without the axles and drive shaft and drive it then. see what you got. Have you ever pulled the differential cover from the 10 bolt front axle? That would be a good place to start. Report back.
