xerofuzzion
- 0
- 0
- Dallas Texas
Agree with draining and opening the inspection cover. New gear oil isn't expensive and it tells you more than peeking in through another access port. Be sure to get the anaerobic sealant recommended, for the inspection cover seal. It's available at auto parts stores from Permatex and others. Just follow the directions and no worries. It is used on other spots too, so it won't go to waste after this single preventive maintenance action.there are 4 bolts on the steering arm. Take the 8 bolts out of the inspection cover if you want to see inside...
