9.00 x 20 snow tread
tm america
23
merrillville in
nice job they look really cool like that .now you just need to test them in different situations vrs uncut 9.00s and vs newer radials so we all can see the difference .i'm sure it makes a huge difference in how they preform
tm america
23
merrillville in
i wonder if that will help with tire wear to as each lug can now move separately from the others rather than being rolled and streched .not sure i'm explaining it as good as i could but you get the idea:roll:
nice. im putting number 10 blade grooves on my ndts 3/8 deep x 5/8 wide. pretty much the same place as your center rib cuts i have a number 2 so i might put a side cut to. yours look good
Sounds like your going to do what I did on another set of tires. ( I have a bobber so I only run four ) Under The Deuce form in Goodyear radials SUCK in the snow!!! thread, post #38 is a picture.
I used #5 to take out the center rib and #2 for the small cuts
