915 valve leaking air is this supposed to be?
krall
shippensburg PA
Ok I turn off the m915 and it hisses ( after all the air has filled up) the air drains out everytime, its not fast but its steadie, I got up inderneath the hood and was feeling around ( Icouldd hear it but didn't know where it was coming from) found this brass valve, on the back of it there is a filter of sorts and if you put your finger over it, there is a good amount of air coming out, is that right?
valve is located on the front of the engine on the passangers side of the engine and has air supply to the shaft that the fan is attached to.
any ideas??
krall
shippensburg PA
first pic its on the lower left, the back of that is where its excaping, second is top left, took at amore of a distance to give an idea of location, located beside the front head.
Hammer
393
Winlock, WA
It is leaking out of the vent portion of the valve.
Pull it apart and check/clean it. Most likely solve your problem (unless it has a bad o-ring, but those are easy to fix.)
Looks like it is the valve for activating the clutch for the fan.
krall
shippensburg PA
ok that sounds like it, I pulled the small air lines off no problems but don't have correct tools to pull the valve here at the house, will have to tinker at a later time, its not hurting anything is it? or is that a must fix right away item?
cornrichard
Galesburg, IL
Yeah, they all rattle. They are usually louder when the compressor is about to shut off. I just picked up a rebuilt drier for one of my trucks. I should be an expert on their insides by this time next week. I am just swapping the insides and bottom cap so the color will not change. My new unit is bright blue.
krall
shippensburg PA
nice that woudlnt' look out of place, haha, would you possibly take some pictures while you work? I would love to see the insides and kinda get a grasp of what I am doing befor I take it on, appreciate the info.
