92' M998 Horn problem
Milcommoguy
2,167
Rosamond, CA
You got the lighting switch on SERVICE. Needs to be. Next... Check to see if you have one up front and two wires going to it. Next... pull the clip ring off from around the rubber button and check / clean up wiring any rust junk. Make sure not to loose the center wire down the rabbit hole steering shaft. This is the one THAT (another test) if you ground it the horn should honk. Remember the lighting switch above, MUST be on. AND remember old truck, old tired horn or worn button?
AND...That's all I have, BEEP BEEP road runner, CAMO
AND check the ground to the column just behind the dash panel. little hard to find. Lots of AND's and IF's
AND the reason for all this... Ya don't want to be BEEPING when sneaking up on the bad guys or flashing headlights. At that point it wouldn't matter.
  • Like
Reactions: REF
Coug
4,241
Olympia/WA
Al Milcommoguy said, have to check all those places and make sure the switch is on.
It's also probably not powered how you would think, when the light switch is in service or drive positions, the wires are live to the horn, then from the horn it goes to the button in the steering wheel. So there WILL be power at one horn connection, and then through the horn.
  • Like
Reactions: REF
papakb
1,184
San Jose, Ca
The spring contact on the top side of the steering column on mine was broken when I got it. This is the contact that grounds the column to the rest of the vehicle. Without it the horn won't work. It's a simple 2 screw and 1 wire repair.
Here's the info on this part:
92'M998
Bullard, TX
I see the problem i think, we were trying to use the horn in the RUN positon, didnt work on the road either before we messed with some of the cables that were undone
Milcommoguy
2,167
Rosamond, CA
Well... Ya didn't tell us that. 😬
Get ready for the "study the TM's" in your spare time. 📖
It's all in the owner's manual, CAMO :rolleyes:
