infidel got me
- 32
- 48
- Newberry, Florida
Hey guys I need help on this one. Yes I did check the tm's for this, but it gave answers that were obvious, and left me in the dark.
So here is what happened- started truck- moved truck to ft.yard- moved car- went back to truck that is now not running- try to restart wont run - gave up. The next day I went out and tried to figure out what happened- I found a blown fuse under dash on # 10 wire. I've read that the control box can do weird things, so unbolted box and opened it up. It had a melted diode on the top solenoid. I ohmed it out and went to radio shack and napa replaced diode and solenoid. Anyway the fuse on #10 wire wont pop a fuse with control box unplugged-I don't know if this fuse has any bearing on running/starting issue. Pulled fuel filter canister and it was only half full, so topped it off and tried to restart - no go. Primer lever will pull out but will not push back in easily. Truck will run on ether. I added air to tank to check for fuel leaks , none found . What would you recommend as my next step. The tm's all say fuel related, which I know it is, but I don't know where to look next. Almost forgot , its a 85 250 non turbo
