Easier to pull the cam. There is a puller, but it requires pulling the cam out 4 inches to get the puller behind it, kinda a waste of time, and you need to heat the gear and be quick reinstalling, it will stick easily. The pump gear is not timed, but the pump is.Make sure you TDC the engine and lock the pump before you pull the gear. Follow the torque procedures when re assembling, the pump gear will turn if you don't. Don't leave the pump and compressor on the cover, you CAN leave the pump and compressor on the engine and remove the gear housing providing all of the supports are there for the two components. You'll want to drop the pan too because the front of the pan is mated to the gear housing. Don't use RTV. Oil attacks regular silicone. use a silicone based adhesive. I used a Threebond product, TB1215, it dries like the consistency of silly putty and is oil and heat resistant, I know others like permatex make an equivalent available at NAPA and other auto parts stores. AND, if you have a front cover that is flat, while you have it off, replace it with the newer style "sunrise" type. The old covers leaked all over the place and cracked at bolt holes. The new cover eliminates the leak/crack issue and eliminates the gasket, you only use the adhesive. The pic is of a cover from an ISC, but the mechanical engine cover will look like this except for the front seal area. The ribs emanating from the seal area is why it was referenced as a "sunrise" cover.
