923A2 starter problem
Jeepdoc
California
Any help would be greatly appreciated. I have a 923A2 five ton truck that uses the same starter as a 939. I need to replace the starter and would prefer to use a newer model starter. The motor is a Cummins 8.3 turbo. I've been told by a starter repair shop that a delco gear reduction starter is a good choice. Does anyone have experience with this and could recommend a brand and model number? Thank you in advance for your help.
20,644
NAPA P/N WIL 91013700 for 68-79 NHC250 Starter
Talk to @74M35A2 for other that 68-79
Jeepdoc
California
Thank you for the information Mullaney. I looked up the Napa number and it shows as an 11 tooth unit. I was able to remove the old starter and it is a 24 volt 12 tooth starter. I'm thinking that could be problem? I researched the line of AC Delco / Delco Remy starters and the 38MT and 39MT can be ordered in a 24 volt 12 tooth starter. Any thoughts on either of those? Thank you for your guidance.
20,644
Dang. Well I would touch base with @74M35A2 .
He is great source for Civi Alternators for 5-Tons - WITH Brackets as well as starters.
M35A2-AZ
423
Tonopah, AZ
You are right the starter for the NHC250 is not the same as for the 8.3L
The starter for the 8.3 and M35A2 are the same. I have one for sale if you need one.
PM if your interested.
20,644
He can't PM at the moment. Not enough posts yet.
I will link you up...
