TexAndy
- 16
- 38
- Bee County, Texas
I've been trying to get my cooling fan to come on with no luck.
Replaced the shutterstat with a 190 (originally had a 200). The fan clutch does work(tested with air, directly). The shuterstat IN line is getting air. Coolant reservoir is filled to bottom of fill tube
BUT... the water pipe the shutterstat is threaded into is only getting up to about 110, measured with non contact thermometer.
Gauge in dash read 200.
sides of engine block was 155. Water pipe at shutterstat 110. lower half/side of coolant reservoir was bout 145. Passenger side of radiator (solid metal portion) about 135. Driver side of radiator (solid metal portion) about 100. Center of radiator (inboard side) about 95.
Exhaust manifold about 260 or 270.
So, I'm wondering I have a bad water pump, bad temp gauge, or both?
What concerns me is that the water pipe the shuttersttat is threaded into is so much cooler than the engine block. Same for the radiator. Clearly, the shutterstat is not opening because it isn't getting warm enough. But is that because coolant isn't being properly circulated or because I'm not letting the engine get hot enough overall?
I'm just not sure what the temps at various spots are supposed to look like in normal, everything functional condition.
Any help would be most appreciated.
