936A2 Gas Tank Problem
rumplecat
206
North West Arkansas
I was gifted seven hundred gallons of JP8, tried to fill up the wrecker and fuel cap drivers side will not budge! When I lean into it the filler neck starts to unscrew from the tank! Any known remedy for this without removing the filler neck, I know I will get crap in the tank during the removal! I have tried kroil oil and a hammer with no results!!!
simp5782
Feo, Fuerte y Formal
9,260
Mason, TN
That is just the basket you are unscrewing. It's stuck cause steel brass and aluminum do not mix. The baskets usually rust away anyway
98G
Former SSG
4,012
Two large strap wrenches. On to stabilize the strainer ("basket") and the other to remove the cap.
This is most easily done off the truck. The strainer can be omitted afterwards if desired.
Removing the strainer as a unit with the cap should not pose any additional risk of contamination, but your eyes are on the truck and mine aren't.
rumplecat
206
North West Arkansas
When you say strainer you mean the mesh strainer inside the filler neck below the filler cap? When I try to unscrew the filler cap the entire filler neck tries to unscrew from the tank, I can see the paint break where the filler neck goes into the tank!
frank8003
4,976
Ft. Lauderdale, Florida
So just take out whatever You can get and free it up on the workbench.
Would JP8 be to "hot" for your engine without cutting it with the new useless pump diesel fuel We have now?
dmetalmiki
2,026
London England
That is one weird filler cap.
first it sits atop a large round spacer, and then lo', In the next picture it sits FLUSH to the top of the fuel tank!!??
If that spacer is actually there, then tap 'vigorously' the fuel top with a small hammer to "Break" the seizure, Then one LARGE Gripper (Stilsons) to Hold that spacer
And Another LARGER gripper (Stilsons) To hold the cap.
Then, Work them in opposing directions.
It would be good though if you had helpers to hold and tap though.
Then again, if that "spacer"? has mysteriously disappeared again..!? It's Tap vigorously WHILE working just that Cap.
98G
Former SSG
4,012
That 'spacer' is the top of the strainer.
The threads are all normal right hand thread. A strap wrench or two is the solution.
The first time I encountered a stuck one, I was worried the strainer was left hand thread. It isn't. A crowbar and a military issue web belt got it to break loose.
I'd be interested in hearing back from the OP to see if he has resolved it.
rumplecat
206
North West Arkansas
Not yet, holidays have top priority, I plan on going down to the museum tomorrow to work on the M715 and run the wrecker to air up the tires(has to be done every two weeks- CTIS issues) I will try the strap wrench idea, tried the hammer already!
G744
3,478
Hidden Valley, Az
Yep, leaky stuff that inflation system.
I put tubes in all my 20-bolt 10" wheels, no leaks over lots of time.
My M54A1 goes just fine in the Sonoran desert sand here without letting any air out, too.
DG
