936A2 trans shift problem
funky winkerbean
9
whiting nj
When i put rear pto in the trans seems to upshift and turn hydraulic pump way fast. I am getting 190 psi at the rear of the 5th speed solenoid when lever is in gear which should be normal? Also when throttling up to 1400 rpm i can feel trans shift and all boom functions are way to fast and hydraulics make noise. System always worked normal then just started overspeeding. Any help would be appreciated.
