94 hmmwv
Bulldogger
745
Quantico VA
+1 If you're not an enthusiastic wrench-turner, you might be disappointed. I don't mind it myself, and am a fair mechanic. We also take care of our own with advice and when you have the good fortune to have a buddy nearby with the same ride or similar, you can trade maintenance days helping each other.
It's not a trivial vehicle to own, and they do require routine maintenance same as any other piece of industrial equipment. Parts are often sourced online, except core engine stuff. "Fix it Today!" is not as common option / situation, because of parts availability.
I like mine, but I wouldn't drive it daily myself. Loud and unruly, hard to park in the city, etc.
Plenty of guys DO drive their daily. So yes, it's done.
Bulldogger
As frank pointed out do you do your own maintenance ?
Your probably not going to find many local auto repair shops that work on them ( or if they try they don't know what they are doing).
Mv's tend to be owner maintained vehicles.
Action
1,564
East Tennessee
Food for thought
I know of a civilian Hummer, almost new, that got driven off the highway at high speed and went and took out a restaurant 1880's flagstone foundation. No fault of the driver or the truck, It was medical issue.
All the electrics still worked, doors still worked, no intrusions into the cab, black box showed that as it folded up underneath and bent and twisted, the engineered and planned crushing allowed the airbags to NOT inflate as there was not enough G's. This all happened in about 4 feet of foundation which dead stopped the truck.
It was totaled beyond repair but the driver went uninjured. The transmission went down and the back of the engine went up. I have about a hundred photos if anyone is interested but that truck is really built well. The husband went out and bought Her another one.
But I suspect you just want the tactical military type truck. Here in SF the civil trucks run all over the place (Casinos, lots of money) but the military versions I see and know of just a few.
Both versions are expensive to keep up.
Airbags wont deploy if there arent any.
frank8003
4,989
Ft. Lauderdale, Florida
Airbags wont deploy if there arent any.[/QUOTE]
I verbose but that is essentially what I was saying, Thanks.
My sentiments exactly
Only gottah get almost killed one and twice to change ones mind about what flavor vehicle one drives.
I know people that STILL will NOT wear seat belts!
Strange they always wear them on aircraft! They have to.
I would go for the wrecker for 6K and drive that 10 miles a day.
biggdadd58
Wheeling WV
Couldn't respond on many of these yet. Yes I can maintain on my own as long as there is a manual to reference and I have the place to park. Creature comforts aren't that important, I have other things to drive. Someone stated earlier that there are 55 of these in my area for sale, I can not find them close. Only found one that the owner says it is a 6.5, can not tell me what type it is and does not know about the transmission, 3 or 4 speed and is hesitant about test drives.
Go test drive one. Only then will you be able to answer your own questions.
In past threads you said you wanted something different. It fits that requirement.
But so does the civilian version.
We have all asked you in past threads if you plan on doing your own work on it or paying someone to do it.
You have replied you don't mind wrenching on it but at this time don't have much time to do so.
Like Porky and others have said if you don't end up doing your own work on it , finding a shop to do the work may be a problem.
Parts for them aren't always easily available like going to the auto parts store.
Do you have a place big enough to park it out of the weather ?
They all leak eventually.
Do you plan on being able to have a normal conversation with another passenger while driving? ( not going to happen without investing in some form of crew comm. in HMMWV)
Civilian version no problem.
You like creature comforts? Heat A/C, music? Civilian version no problem. HMMWV not impossible just more money out of your pocket.
Towing:
HMMWV's aren't set up for towing civilian based things. With that said you can convert to tow stuff just more money
Do I think your nuts for wanting one? No
Do I think your nuts for wanting one as a daily driver? YES
Find one and test drive it.
Only then will you know if your scratching an itch or have come down with MV fever.
biggdadd58
Wheeling WV
I want to thank all of your for the input. I just need to find one close to test drive and hopefully I can find 2 of them with both engine and tranny set ups to compare. With our business name, I would like to dress it up and take to trade shows that we attend to help show it off and be able to take pictures with customers as well to pass the day.
Action
1,564
East Tennessee
Ask the seller to take you for a ride. I wont let folks test drive my vehicles. My insurance company advised against it.
Look for a "P" and a "D" with a circle around it , on the shifter. That will be a 4 speed
TOBASH
3,913
Brooklyn, NY
So if the guy doesn't know his car why would you even consider buying it.
If you don't know cars, and you don't have time or $$$ to repair, I suggest you avoid purchase.
Your questions are so basic that I have a tough time thinking this is the type of vehicle for you.
Best,
T
biggdadd58
Wheeling WV
Basic questions aren't the same as having the ability to fix or repair, thus the reason for questions about something someone is not familiar with. I didn't know before talking to the guy selling the unit didn't have the answers for my questions.Maybe, just maybe, this could be a diamond in the ruff, who knows. So if my questions are so basic and my lack of knowledge upsets you that bad, maybe you should just overlook my ignorance.
Best,
T
Bulldogger
745
Quantico VA
The problem with the seller not knowing what engine/trans combination he has and whether it is original, field-modified, or after-market modified, is it raises red flags that he's flipping it and probably has done VERY little maintenance beyond an engine oil change. It took me several days of evenings and a weekend to do the complete lube order on my ride once I took possession. It was straightforward, but not fast or necessarily cheap. By doing all that I confirmed every detail of the power train, knew what I had to repair/replace in the near term and also found several little things that could have become big things if left to fester.
The seller does not appear to respect his rig, and whether it's a diamond in the rough or a snake in the grass is unclear. A lot of people tried flipping these during the brief heyday of GovPlanet sales. Many were not worth the asking price and had no proper preventive maintenance done.
Unless it's drive-able and well under $10K it could be a nightmare. They are all money pits to one degree or another, they are industrial equipment, they are not inexpensive toys.
We're trying to help you manage your expectations.
I personally don't have issue with the "no test drives" stance, I don't let people drive my HMMWV without an open field handy or some indication they've ever been around one. For the inexperienced, it's tricky handling an 8' wide vehicle while sitting very off to the left side as compared to a normal civvy vehicle. There is some mental recalibration needed.
If you can do a recon and bring back some pictures and observations, this group can give you a lot more detail to chew on. We're spitballing here, so answers will vary widely.
If you feel like a nice (long-ish) drive next weekend, the Glen Allen VA VFW (near Richmond) is having their Tanks and Trucks event from 10-4 on Saturday the 17th. There will be multiple HMMWVs there, including mine, and you can get to know one in person. PM for details if interested.
Bulldogger
porkysplace
1,495
mid- michigan
A good way to overcome " your ignorance" as you put is spend some time reading the forum and educate yourself . almost every thread will have peoples experience and the pros and cons . The amount of effort you put in learning about them before you buy will directly effect how much you spend after you buy . These were designed at operate at a convoy speed of 45 mph not 70 mph down the highway. If you do some reading and with what has already been posted in each of your threads buy one with a JEP 6.5 and 480le transmission if you want high speeds . Most everyone who has upgraded one will tell it is cheaper to spend the money up front than upgrade a 6.2 3 speed.
biggdadd58
Wheeling WV
Very well put, thanks!
Bulldogger
TOBASH
3,913
Brooklyn, NY
So far your questions are so basic as showing you have not read anything on this forum and you're not aware of even basic things like transmission options AND you've asked questions about swapping in 4 speed trannies, which is a Herculean job. You've also said you don't feel comfortable looking over certain things and are requesting assistance. You also said you're not someone who wrenches or works on stuff.
You've been on the site less than 2 months and its apparent that even when looking for a car you don't see giant red flags when a HMMWV owner doesn't know things like 3 or 4 speed in his vehicle for sale.
You mention it might be a "diamond-in-the-rough", but you haven't even see it OR been allowed to drive it, AND the owner sounds like he doesn't want to let you drive it pre-purchase.
GIANT RED FLAGS.
I'm not here trying to beat up on you. I'm trying to save you a World of hurt and pain and $$$$$$.
Stick around, search the forum, read posts for the next couple of months, and silently lurk around to see the problems others are dealing with, ESPECIALLY with Winter weather on the way.
Buying an old Dodge is easy, you can have a dealership service it to bail you out in an emergency. Not so easy with a HUMMWV. And unless you're a Rockefeller, you will need to wrench or pay $$$$$$.
Just look up PCB and see that just a simple protective control unit, a unit that is essential to operate these rigs, is a $700 headache waiting to happen. Then look up my posts trying to wrap my head around creating a PCB bypass to see there is a lot to know just about this stupid little box that we cannot yet live without. Then there are stuck and broken glow plugs, power steering hydraulics used to operate power brakes, fuel pumps and fuel injection pumps that break down, stuck doors, broken directional controls, 24 Volt starters... The list is endless on these old vehicles that have been rode hard and put to sleep wet every working day of their lives.
SO if a guy has a car for sale and won't let you drive it and he doesn't know what kind of transmission he is running and you don't see red flags, I see a setup for disaster. You're the one I'm looking out for, not me.
AND, as you want to walk blindly into this lion's den AND you want to take insult in my attempts to help AND you make statements like "maybe you should just overlook ignorance", maybe you're missing the point and getting your skirt blown up for sake of not understanding.
Your choice. Buy a lemon from an owner who won't answer your questions, or trust some free advice that is warning you that you seem to be unprepared at this point in time to purchase a HMMWV because you need to do more homework.
Your $. And you know what they say about fools and $ and ultimate separation of the 2.
There is a member who reminds all that there are 500K HMMWV's out there, all waiting to be purchased by one of us at some point in time. There is no rush to have to buy one now. My feeling is why are you rushing things when at this point in time you don't even know what you don't know.
If you want, I will not bother you again, or offer advice and such ever again.
frank8003
4,989
Well, 33 posts and the original poster must have got all your messages by now/..........
I don't know, I just innocent bystander here.
The facts have been laid out for all to see.
How could We do better?
But there should be pictures for the General and there is none.
Maybe it is all fake news?
biggdadd58
Wheeling WV
To a point, there are answers. As far as pictures and the "fake news" comment, not sure of what you are saying. I thought the point of forums was to communicate. My apologies to all!
