95 m1078 starting issue
tjair99
West Virginia
So did a cab swap on my 95 1078 with 3116 cat and now it won’t start from the cab have went through the relays all seems to be working correctly except not getting a signal to the aux relay on the frame rail truck will start and run correctly if I start it from the frame relay the wiring was transferred from the old cab and everything worked correctly before swap only thing I’ve noticed decides the start issue is my fuel gauge is not working correctly so I’m not sure which wire to test from the dash down to the frame relay to see if it broken somewhere lol any help would be appreciated
