Pstyckiewicz
- 75
- 28
- Massachusetts
I have an M1152A1 with the stock2 man A/C unit. I am just getting into the stage of fixing the A/C. The fan switch works on the dash. The vents blow air but it’s not blowing cold. I don’t hear the fans under the right rear wheel well turn on. I did hear them come on once before for a second. I’m not sure if I have a leak somewhere or if I have a bad low or high pressure sensor. Maybe a bad ground or wire issue.
I’m looking for somewhere to start. Maybe what wires to look at or connections to jiggle. Or O-rings to replace. I do have access to a vacuum to hook up to the system but I want to check the simple things first.
Any help is greatly appreciated!
