- 3,312
- 1,263
- 113
- The actual midwest, NM.
Even if it is truly 7,000 I'd still guess it's a rebuild like ya mentioned. I've only seen about 20-30 Detroit motors but none were yellow, fwiw.It doesn't look like it, but then I haven't even put this one on the lift to check things out yet.
Wow, what a small world. Yeah, this one came from Utah so it almost has to be the same one.I have seen one and with the same mileage you have. Does this happen to be in an M1031 that is painted Black? If so I know for a fact that it is actual miles as the underside shows little to no use. I owned it atone point if it is that rig.
