- 10,350
- 75
- 48
- Meadows of Dan, Virginia
Installed the differential oil pressure on the 8x8, previously used on the deuce.
It displays the pressure drop across the oil filters and oil cooler. To my surprise, it indicated less than 1 (one) psi, I had expected about 5 or so based on the readings from the deuce. Now I'm wondering if the bypass valve is calibrated correctly or perhaps even disabled...
