tco3129
- 4
- 0
- Flat Top W.V.
Do you remember where? Got in a pinch and went to NAPA. A quart cost me over $40 OUCH!i instead found a dealer who was selling it shipped for 65 dollars
True, but that little sticker can be removed.The use of DOT3 is debatable. Silicon brake DOT 5 is the correct fluid according to the TM's.
I understand the truck was originally supplied with a DOT 5 brake fluid system.I think the decal is to ensure the operator uses the correct brake fluid. The corresponding number matches that of the silicon brake fluid container. Take a look.
There are enough people converting to DOT 3 without their trucks exploding that you can at least admit it can be done properly, so telling people they absolutely must use DOT 5 is not true. Yes, it was designed to use DOT 5 for military purposes. I'm modifying my truck to work for my needs now.
I think they were actually designed for DOT 3 and converted to DOT 5 later on by the military, for their purposes. I do not know this for a fact, just seen it pointed out in other threads before.
I was think this same thing while reading the thread, but perhaps I have my facts wrong?]I'm modifying my truck to work for my needs now.
Sounds like you would have to do a complete brake overhaul to avoid mixing. It's not as simple as filling up a pressure bleeder with DOT 3 and pumping out the Silicon Fluid.Hey Loco. Just my opinion which is based on what I was taught at a vo-tech, don't switch to DOT 3 unless you are going through everything. (MC, air pack, ALL wheel cyls, replace flex hoses, best job humanly possible to clean hard lines) I have always advocated that it would be great to do that, then be able to use much cheaper and widely available DOT 3. But if you don't intend to do it all, I would stick with DOT 5. Not trying to sound harsh, but don't switch back and forth, back and forth.
Me personally, I have always wanted to switch one to DOT 3, but have never needed to re-do the whole brake system yet on a truck. That combined with shear laziness has kept me buying surplus DOT 5.![]()
That would be best, without a doubt. Now could you get away with just pumping DOT 3 in the system? Maybe, and I am sure it has been done. I just know its best to start with fresh rubber seals in everything as one fluid tends to shrink rubber, while the other expands it. Also like you said, just to get all of the other fluid out would be very difficult without rebuilding all of the components.Sounds like you would have to do a complete brake overhaul to avoid mixing. It's not as simple as filling up a pressure bleeder with DOT 3 and pumping out the Silicon Fluid.
