Katavic918
- 54
- 28
- Maryland
I recently bought a HMMWV. When I went to pick it it was the first time I have ever even touched one. So as you can tell this is a learning experience from the start. It is a 1991 m998 with a 6.2 and th400 trans. I have been in the mechanical\technical field for 15 years and have a pretty good grasp on was right and what's wrong. That being said, I reasonably believe that everything is operating as it should but there are certain things that I would like to know if they are normal.
1. When I start it whether it is cold or warm there is a surging in the charging gauge. It is a repetitive increase and decrease in voltage. This lasts for about a minute and then like a switch is flipped it returns to a steady voltage.
2. Is it normal for a 6.2 to sound like a sack of hammers. No loud knocking or anything like that but it is a clacky sounding motor. 45 psi oil pressure and no smoke.
3. Is it normal for the back tires to lock up in an emergency stop. I test braked a couple times on a dirt road and the rear tires lock first. It feels like the fronts are doing their job but the rears are locked at the same time.
Thanks a lot for any thoughts.
