Why?Really dangerous idea
RE A-Frame mounting alone;
I wonder if you could mount the A-Frame poles at the bottom
and use the top for support chains and eliminate that pita cable
over the top to the rear?
Look at the leverage the length of the A frame puts on the tether that would go over the cab - it would be similar to the load being lifted - approximately similar angles. Now look at the magnification of torque put on anchors that are only a bumper height above the pivot - upwards of many tens of times the load if not hundreds, like trying to use a pry bar the other way round - pushing on the chisel point to raise the handle, pivoting on the heel of the chisel point. What you'd end up doing is shearing off the top shackle bolts with minimal load and the whole lot would come crashing down in a hurry.Why?
Darn science and math,,,,,,mao!!Look at the leverage the length of the A frame puts on the tether that would go over the cab - it would be similar to the load being lifted - approximately similar angles. Now look at the magnification of torque put on anchors that are only a bumper height above the pivot - upwards of many tens of times the load if not hundreds, like trying to use a pry bar the other way round - pushing on the chisel point to raise the handle, pivoting on the heel of the chisel point. What you'd end up doing is shearing off the top shackle bolts with minimal load and the whole lot would come crashing down in a hurry.
Keep with the over the cab tether idea. Can put "goal post" behind cab to move tether up and off of roof.
Could even double up the front wheels, like rear duals, for tire capacity and allow you to travel a bit (hard steering) with suspension blocked of course.
You're no fun. But, when the rear axle of my truck is 8' in the air and most of my diesel fuel is gurgling out the fill cap, I'll crawl back and say you were right.The frame of the truck is much less substantial than any crane. I wouldn't do it.
A pesky thing called work got in the way of me responding quicker. It is funny how you can change the geometry and increase the loads by an incredible factor.Look at the leverage the length of the A frame puts on the tether that would go over the cab - it would be similar to the load being lifted - approximately similar angles. Now look at the magnification of torque put on anchors that are only a bumper height above the pivot - upwards of many tens of times the load if not hundreds, like trying to use a pry bar the other way round - pushing on the chisel point to raise the handle, pivoting on the heel of the chisel point. What you'd end up doing is shearing off the top shackle bolts with minimal load and the whole lot would come crashing down in a hurry.
There is a big differenceYou should be able to mount to all 4 shackels.
No different then a 3 point boom pole on the rear of a tractor.
I have an M37 sized boom on my M37, much like the one in the picture, but without the 2nd winch. It has the headache rack - a must have option. It will pick a ton & move with it. 2 tons with jack stands under the bumper. Safe? I don't know, but nothing is safe, unless one uses care. The 1st problem will be that once you have a boom, you will keep using it... so be safe! A couple of points that I will make is that you can raise the boom to the desired angle, if you have a clevis on the corner of the headache rack, thread the winch line through the pulley on top of the boom & then back to the corner of the headache rack. There will be some strain until the boom gets raised a bit, just like on real cranes. I just have a pined plate on the top of the boom that I hang a snatch block in. It is very important to have that hole lined with the center of the axis of the legs of the boom. Otherwise it will induce a "moment" in the boom legs, which can lead to structural failure, in extremes. Yes, the back end can come off the ground. When I was much younger, my response was a 1/2" in the back - its still there, and still running.Some kind of a head ache rack like on a bolster truck might be an option. Make it look like a permanent first hood hoop but stronger?
Yes, too much tension to place the crane boom tie back that close to the boom itself. I bought a second 20k hydro winch to place at the rear of my frame under the bed. Will have a trap door that flips up from the bed floor, and can extend the cable up through the bed, and then over the top of the cab with some sort of guide post, this is still TBD design until I have the winch mounted, but I may do another drop leg for the tire crane and then a sheave on the tire crane horizontal pole, or something like that.
The picture posted was nearly what I had imagined, thanks for posting it. Only difference is to use a single tether cable to the center mounted rear winch, should be OK. Easy to control boom angle then. Only problem to overcome will be when the crane boom poles are initially lying down on the ground, the angle will be steep in a down direction and the tether cable will drag heavily over the cab roof and maybe even the hood edge. It is like I may need a nylon block with a groove cut into it to guide the cable across the cab roof while it has minimal load on it, or something of that nature. The roof structure on the M939's are all but strong...... Just the wind blowing across their top can make them oil-can. Ugh...
What about a roller on the spare tire davit?The boom is done, as pictured. Next step is to remove the bed to set the rear hydro winch in place, cut an access door in the bed floor, and then route the cable up and over the cab. That has not happened yet. I'll have to develop some type of pole for the cable to go up and over the cab.
.Speaking of "really dangerous ideas"... trying to lift something that requires adding two more 10,000LB capacity tires to what I believe is only a 14,000LB front axle? Although I'm always up for some destructive testing if someone else is paying the bill!Sent from my iPhone using Tapatalk
