A HD ex-military 8X8
Alaskossie
From my small archive of photos of odd vehicles, a few photos of the ex-military 8X8 owned by York Steel Co. in Anchorage, Alaska. I only saw it in action once -- winching a 5-story apartment building on rollers to a new site half a block away...
I don't know the original military model. It appears the owners added a frame extension and another driven axle on the back. Anyway, a pretty heavy-duty outfit.
Alaskossie
1,142
That was a 10 ton, some kind of M123 variant-see the extra little foot thingie under the right running board?
maddawg308
793
Appomattox, VA
Do you know if this beast is for sale? If it was a 10-ton M125, it may be able to be salvaged by hacking off the rear axle and part of the frame, and grafting on a 5-ton bed.
FreightTrain
Banned
2,730
13
Gadsden,Al
what I want to know is what was the fate of the OTHER 10 ton?The donar for the axle,wheels,and tires....something had to die to build that thing...
123mack
11
Jemison, AL
Looks to me like a converted M125 too. Gas tanks aren't stock, but 5 ton tanks are the same. With my M123 , one of the hardest things has been to find good used 14.00x24 tires, in any tread. Anyone know where I might find some inthe southeast?
DDoyle
West Tennessee
As ya'll know, I'm not usually much on mods - but whoever grafted the frame of that M125 such that it can take the power of the big LeRoi and transmit it to that pintle deserves a nod.
They were shy about the front bumper either. The bed of the M125 is unique - and very hard to find. Would be nice to know what happened to it - but as the truck belongs to a steel company - I gotta pretty good idea its been recycled.
Regards,
David Doyle
pa.rich
I was looking to see what the spring arrangement was on those axles. Man, what a truck! Is that front axle in the triple set a tag axle with air? I had been wondering why you couldnt add as many drive axles as you wanted since they are the same in the back.On my 5 ton at least.Hmmmmmm.Then you have to add the double steer up front too :shock:
maddawg308
793
Appomattox, VA
David, wasn't the bed of the 10-ton M125 the same as a 5-ton cargo?
123mack
11
Jemison, AL
The springs are what many refer to as a camelback suspension. It is still used on Mack's heavier trucks. The rear axles are rated at 65,000 lbs each, with a ratio of 9.02:1.[/quote]
jh1990
RE: m125
I like it, I want to do the same thing w/ on a 5 tonner but have the first drive and last drive liftable. Then again my plans call for a 10spd and a bigger Cummins. Not to mention another 5 ton cab. :driver: :twisted:
