a3 pickup
goodguyzy
13
medford oregon
tomorrow i will pick up my A3 from GSA. Spoke to the contact that said it will start and is ready to drive. Ive read the past A3 post till im ready to fall asleep but still would like to know how to check the brake fluid. is it the same as an A2? or if you would like to advise on anything else im all ears
thanks
mktopside
Banned
467
Gainesville, Va
It's under the hood in the left side of the firewall, you can't miss it.
Bring some ear plugs, while my A3 is quieter than my M1009 at idle, the road noise will rot your brain over 45mph.
Good luck! You'll love the truck.
365
Anderson Creek, NC
The break fluid has two reservoirs. Dot 5 make.sure the oil.and.trans.fluids are.ok. Check the expansion tank level for.coolant. Mine had a JB Weld field fix.that leaked. Make sure.all.tires are properly inflated,.and.check them each time.you get fuel. Just basic.stuff. Trans fluid dipstick is under passenger floor mat.. Dextron is FLuid of.choice. My.recovery was a.blast, very much fun. Good luck. I hope.your.batteries.ate.better than mine were. Always keep in mind that you may.have damaged.sidewalls on the tires. So, one may fail on the highway. If it is.not turned off already,.do so as soon as you start it.up the first time.
