A3 Tires (14.50) on an A2 Truck
JimmyThompson
McDonough, GA
I'm looking to get seven A3 "Super Single" tires (14.50 r20) to put on my M109a3 that currently has the standard tires on it now. Do these just bolt right up or is a hub flip required/mandatory for the rear axle?
glcaines
2,581
Hiawassee, Georgia
As Welldigger said, you will need to flip the hubs. The 14.5 X R20 tires are getting in short supply these days. Are you sure you want to go that route? You may want to look at 395s instead of the A3 tires.
gimpyrobb
dumpsterlandingfromorbit!
27,786
751
Cincy Ohio
Can you be sure the tires didn't sit flat?
The tires will destroy themselves if they have! Sitting flat, which happens on most A3 trucks, breaks the belts in the tires.
I would shy away from any A3 tires that are not new.
welldigger
15
Benton LA
I just picked up 7 395's in the 70-80% range for $1260. I picked them up in Hooks TX from a tire dealer there. They will also ship via freight. Don't know how much that would be though. PM me and I can give you the guys #.
Edit: I see your in Georgia. Take a look at www.militaryoffroadtires.net. You may can even do local pick up. That will save you a bunch.
gimpyrobb
27,786
751
Cincy Ohio
No matter what you do, I would make sure I inspected the tires before you buy them, unless they are NEW. This is one area where things are VERY subjective and "grey areas" abound.
welldigger
15
Benton LA
Ditto. Though, a dealer ,I won't specify, sold a buddy of mine a "new" 14.00-20 xzl and it had a gouge in the bead. To be fair it looked new other than this defect. The tire is holding air for now at least.
Ford Mechanic
Edenton, NC
Thanks, I came across some one who had a couple, just wanted to know the sizes before I went and looked at them.
I found the info I was looking for after searching more, so I'll post it here in case someone else runs into the question
14.5r20=43in
395/85r20=46in
http://www.militarytires.com/
