About our transmission...
Trango
23
Boulder, CO
It's too bad the spicer 3000 series is completely obsolete, because otherwise, you'd be able to do cool stuff like swap that input gear for one from a different model within the series (along with the corresponding input gear on the countershaft), and really play with all the splits across the ranges (aside from the 1:1 gear)...
Bob
1ton
Lawrence, KS
Installing larger tires doesn't affect the actual gearing any where. But since smaller tires have to spin more times to travel the same linear distance they have a lower- Higher numerical value gear ratio.
ndccs are probably different but theses are close enough.
9.00 517revs/mile
11.00x20 482revs/mile
14.00x20 431revs/mile
All you need to think is small tire=torque, big tire=speed.
1,815
Now, if you guys want to really get screwed up, have a gasser deuce and a multifuel deuce and drive both. I did just that many years ago when I had the gasser M275. It was a major brain burner trying to remember what truck I was driving and what gear came next. Another side note, Wayne Harris bought a Multifuel deuce from Ft Stewart that had the 2052 tranny in it. Ran great but was absolutely screaming at 50.
rmgill
14
Decatur, Ga
Worse is when I try to shift into 5th on my Honda Insight and go right and Down instead of Right and up. (Right and Down being reverse!)
I've done this 3 times now. :(
1,135
I have seen that as well. I saw it on an A1 with a 427.
