Third From Texas
- 6,676
- 113
- Corpus Christi Texas
Rgr all.
Not looking to go into production, but I've enough engineering background to build something this simple to spec. The specs for every hole tapped into a C7 is pretty well documented online. With a compressor in hand to make the other end, it's easy to get the other end spec'ed. What goes between them becomes simply a matter of time to plan and make.
Funny that when someone here was selling only one of the two bracket set (and the correct bracket is in fact a two-bracket set) no body gave them this much static (the seller flat out and absolutely incorrectly stated that the second bracket wasn't even needed).
Look, at the title of the thread here.
If I were not looking to make the damned thing I would be in a seller's PMs asking to make a purchase. This thread really isn't that....
I appreciate where you're coming from and as I said, I fully support purchasing from vendors who make their own wares (I've purchased from you in the past). But there are some things I can and would rather do myself.
