74M35A2
- 332
- 83
- Livonia, MI
The compressor comes with oil as long as it was still sealed and not spilled out. That is enough oil for the components and system it was designed for. If you added longer hoses or a larger condenser/evap, I would probably add a little more.
Should be a single wire going to your compressor clutch. It should come from a system relay or at least a system pressure switch. Power flow should go like this: From battery to A/C control panel, then out to condenser and evaporator fans. Also out to pressure switch(es). From pressure switches to compressor clutch. May be up to several relays, but general flow is the same.
