- 849
- 1,739
- 93
- N. Central Idaho
Finally finished re-wiring the added accessories. I never liked the idea of running power wires thru a switch directly to the item. So I added a relay panel; behind the companion seat.
Control panel L to R: Bar Light, Running lights, back up light, back up horn, cameras (future) and crane.
Didn't wire the back-up to come on when selecting reverse as there are time when I might need them without selecting reverse.
Power is through resetable CBs.
![Power.jpeg Power.jpeg](https://www.steelsoldiers.com/data/attachments/617/617267-244488739985f239b2a680c70b332049.jpg)
Relay panel as well as control panel are installed with connectors so easily removed.
![Relay panel.jpeg Relay panel.jpeg](https://www.steelsoldiers.com/data/attachments/617/617268-ebf0ad4759d10158a0e70107b3126638.jpg)
Relays are mounted behind companion protected from anything thrown under the seat. (Still working on this cover).
![Mounted.jpeg Mounted.jpeg](https://www.steelsoldiers.com/data/attachments/617/617269-334c11df99c82aa84e449103718d5978.jpg)
I did not go to the overhead as I did not like access for the wire run. There is a hole in the center windshield structure on the top but nothing on the bottom. Windshield could be folded and a new hole drilled on the bottom and larger hole drilled on the top. This would be prefect, except I have a fiberglass top that wraps over the windshield frame so would have to be pretty much removed. Then if I ever wanted to run with the top off and WS down I would have to disconnect everything. May do this when I add camera and radio, not sure yet.
![Control.jpeg Control.jpeg](https://www.steelsoldiers.com/data/attachments/617/617265-62d836337890d41b7165613b853607fe.jpg)
