Actuator, Air Fan Clutch for M923a1
winterton1
19
San Diego, Ca.
i havee an actuator that is leaking air through the tiny hole - not the larger hole in the end cap...i cleaned and lubed it. still leaks. should there be an o ring in there. when i took in apart it did not have one?
Defcon-1
67
South New Jersey
I just developed a leak from this little hole as well. The truck sat for 10+ days so I'm not sure if it's related but I will also trying taking it out and cleaning / lubing it. Did you get a fix on yours?
