Add a turbo or get the 6cta 8.3l
6wdcummins83
Hudson valley NY
I'm putting the turbo on and I noticed the oil feed is in the bottom and the larger outlet is on top. That's also the way the arrow is pointing on the turbo, but that seems to be different from the pictures I've seen.??
jarhead1086
Farr West, UT
Mine just barely cleared. I had to assemble the 3 exhaust pcs on the bench to get the hole spacing and bolt it on like a single pc. Mine fit tight because of the ceramic coat, so I tapped with a hardwood block until the hole spacing measured right. I stuck the gaskets with high temp silicone so they didn't fall off during assembly. No leaks when I was done.
wcuhillbilly
Devils Tower, WY
Anyone have clearance issues with the exhaust manifold and the Cooland manifold
yup.... I did,,, you have the "technically wrong" manifold,,,,, dig up my thread "816 Jakes and turbo" and the pics will tell you what I had to do to make this manifold work.... I ended up grinding the arm of the manifold to squeeze it under the Thermostat housing. Then I ground on the thermostat housing itself,,, you can also get a machine shop to mill you some 1/4" spacers to sandwich under the water manifold ports to raise it up for clearnace... Mine has bee working fine. But I keep my eye open in scrap yards for the "correct manifold" Or go find the Thermostat housing off a SC 350 but that opens up another can of worms with the generator and plumbing.
74M35A2
341
Livonia, MI
We now know the correct p/n full size charge air cooler from a Volvo with 4" I/O if you want to route that beautiful 4" tubing to the front and back.
6wdcummins83
Hudson valley NY
Maybe an inter cooler down the road, a different project for a different time. I just wanna get this done haha ran into some setbacks but I'm doing pretty well for not being a mechanic.
