Add the ground kit or equivalent
President Camacho
Florida
Hello from Florida. Where does that grounding kit supposed to install to? Does the stock grounding kit have issues? Is this an engine to frame thing or does it connect directly to the battery?
President Camacho
Florida
Looking at the wire used by kascar the insulation looks considerable. Is it some kind of heat shield they're using? If so the expense of buying this ready made harness may be a good bang for the buck as heat shielding isn't cheap. If it's regular wire insulation then a large cost savings can be realized by building.
