Adding a Third axle to my deuce
Davidwyby
234
CA
I would recommend doing it to a M36A2 with the 17' bed and extra long wheel base. You could put the extra axle in front of the others. If it was me I would just use the front spring kit off of another truck like what we do with bobbed trucks.
I sell 2 1/2 ton rears for $250 and front spring kjits for $300 and even have a M36A2 I would sell.
Derek Taylor
I'd add another steering axle behind the front one I think.
rmgill
14
Decatur, Ga
What about adding a steering rear axle back there? Move the bogey set forwards, and add linkage to the rear axle. Pivot point becomes the center.
Or add the 2nd steer axle under the cab.
rmgill
14
Decatur, Ga
RangerDave
Bar Harbor, ME
Well after a bunch of hemming and hawwing.... Adding the 3rd axle to help increase the safety of hauling capacity may not hold sway with the Commercial Enforcement Division of the State Police.... They are not convinced of many things and I am not sure I can get the truck that was designed for up to 26,000 lbs a boost to something higher.... Like 35,000lbs. So it looks like I will need to run light and get a 5 ton when I decide to get my Comm Dr. License ....
