combat jump
- 4
- 18
- Raleigh, NC
The tank is ready to install
The brackets are from LMC Truck. I also sprung for the "silencing pads" which appear to be nothing more than tar paper. They fit under the steel straps.
Adapting the filler neck hose assembly (a junkyard find) to fit this model of Chevy took some doing. I'll find out if its all correct when I lift the tank into place.
The top of the sending unit has two terminals that I am not familiar with; and that take a special type of connection. One is for an internal fuel pump (not used in this model), so nothing is connected. The other is for the sending unit. I soldered a wire to this (not having the connector) and coating it with "liquid tape" to keep it water tight. Silicone caulk was my second option.
The hoses are a bit long. I'll cut those to length once the tank is attached.
Not shown is a hole I drilled through the engine firewall near to route some wires. I'll get a photo of that later. This will be for the selector switch. I'm thinking of putting the switch in the plastic dash, sharing the same area as the ammeter.
I hope to finish this next weekend.
