corelokt
- 2
- 16
- Duffield, VA. (East of nowhere).
Going to add, (I hope), a water temp, an oil temp, a transmission temp, and an oil pressure gauge. Any idea's where I can plumb in the sensors and keep the dummy lights?
Just a note on that, mine worked great but make sure you use low profile stuff, bushing, close radius 90, then you will not have to remove that oil line next to it. I wanted to be able also to replace any part of that line anytime, I put a fuel line hose on over for heat protection in that area. Made a small wire loom clamp, took out one bolt from oil cooler line clamp made it two for one.There's a small plug just above the oil cooler lines, I'll try that for oil temp. The other intake port cover will get d&t'd for the coolant temp. Oil pressure will be a "T" at the current sending unit. Just leaves transmission temp.
Yes, I think there is one in my photo album, just go to my profile I'll check too. Yes there is one there a decent one as well anything I can to help I will. Oil is on top in pic, trans on bottom. Ext. was not needed, even though I did order one, didn't use, sent it back that thing was 26.00, I did return on oil, feed on trans, why? just wanted to use this as monitor for later aux add on for coolers but I needed a base line to start to see what temps were. If you use that big tee it perfect for probe fits half way down in flow-through. Autometer worked great with me, sent attachments of actual probe size laying on a dollar bill. I brought new AN stuff in for trans looped over top of trans housing built hangers, Stainless -6 lines. If you do that tee on oil don't decrease ID in that area of manifolds (thats what I call them) probe ports. I'll go for now, 1toncucv that took alot of phone time and planning we have a pretty nice farm shop here it's handy, One last thing those bump tube o-rings were're a pita to work around and stay stock,let me know how you do?Mine are mechanical, I broke first water temp gauge trying to shorten probe, going into head, had to order Autometer probe ext. Still working on connecting the others, would you by chance have a pic of probe for oil temp and in line trans? And I do apologize if this seems to be highjacking thread..
