Additional 12v alternator
galaxie428
107
Rushville, IN
Has anyone added a 12v alternator to your humvee with a 6.2 or 6.5? I be interested in learning more about your set up if so.
I have a 24 to 12 converter but I'm getting beyond what my 60 amp alternator can keep up with. I also got a heck of a deal on a 12v winch I'd like to add.
I'm thinking of adding a 3rd battery and moving all my 12v to it, letting the 12v alternator keep it charged.
Miami
I'd recommend a 200 AMP Dual Voltage Alternator be better as it would be able to maintain system load, and also provide a 12V output.
I work on rebuilding military alternators and starters and it sounds like you'd be at risk of blowing the 60 AMP alternator with too much load.
galaxie428
107
Rushville, IN
The cost to switch over is mainly the reason I haven't. The cost of the alternator alone is crazy and then all the pulleys and water pump I'd say you'd have well over $2k in it.
I read on here in a thread that the 12v output isn't much on the dual voltage alternator anyway so could that even keep me charged?
I'd think I could add an alternator for well under $500 with some fabrication of a mounting bracket.
Miami
The output on the 200 AMP should be more than enough to be sufficient, both in terms of Amperage and Voltage, speaking from personal experience, it can provide for both battery systems, when we rebuild them we specifically test for that.
Cost can be a issue however, as most companies charge well over 1600-1800 dollars for them. But if you'd be interested I have quite a few 200 AMP cores, and a few buckets of spare pulleys, I wouldn't mind doing the rebuild for you, it would be significantly cheaper, and I'd throw in the pulley at no extra cost
