adjusting brake lights
Vfflang
Mascotte/FL
is there any way to adjust the brake lights on m35a2. I have to push the brake all the way to the floor before they come on .....and trust me I touch the brakes and I Stop but the brake light only come on if I have it push down hard.
Vfflang
Mascotte/FL
I have a air leak at the low air alarm switch.....after 90 psi It continue to leak out of the hole from the side...with this leak is there not enough pressure getting to the brake switch ...maybe
hoop
14
va
I was also thinking your bumper is too heavy for the front and has a step on the side.
Not really just being sarcastic....now you have 2 things to fix.
Vfflang
Mascotte/FL
New brake switch installed and back in business thanks for all the help .....the low air switch is another story ... does anyone know if the low air alarm 24 or 12 volt and will it work with 12 volt
