Advice on Removing Poor Spray Paint Job
langstonhs
52
NM
I bought an LMTV from a volunteer fire department that spray painted the front and sides of the cab bright red. It is a horrible paint job: no apparent prep, sloppy masking, etc. The red paint is peeling in some places, like around the handles and lights...but everywhere else seems pretty stuck on. My goal is to put the paint back the way it was, with camo that matches the rest of the truck. I tried rubbing the red paint with acetone, but not much came off. Would you advise me to sand all the red off before repainting the camo? Thanks
langstonhs
52
NM
Wet sanding.
I use a 7in polish disk with my Milwaukee grinder to get down to the carc
Aircraft stripper and a good pressure washer
Thanks, but can you clarify this a little? Are you listing three different methods of removing the red paint, or are saying I should do all three of those in that order?
A Seabee
126
33
California
you can try a product called Citrustrip, available everywhere. it may attack the rattle can red paint first and save the better underpaint
langstonhs
52
NM
Thanks. Now I have to figure out what black/brown/green camo paint is on a 2003 M1078. I would like it to match the rest of the truck. Anybody know? I am hoping Gillespie makes them in rattle cans. I think I only need a few. I have searched around SS for the answer, but I haven't found it yet. And no replies yet from the paint sellers.
langstonhs
52
NM
A guy on ebay is selling a set of Gillespie military paint chips (seller: wcfr4). I ordered the set to visually confirm my paint colors before I order paint. When I wrote the sellers, they said the LMTV paint colors were:
"The code numbers are 911-Black, 34094- Green, and 30051-Brown"
Gillespie Military Paint Chip Set
langstonhs
52
NM
UPDATE: I received the paint chip set today, and the paint color numbers I was given by the paint seller are indeed the correct colors for my 2003 LMTV: 911-Black, 34094- Green, and 30051-Brown.
