Aftermarket fuel filters + base
ICAT
Idaho
Has anyone had any luck with off the shelf fuel filters and bases? Only found one thread from 2008 so I'm outting it out there
Cleptomaniac
Tecumseh ,OK
Yes I used a after market filter and base from Napa for my primary fuel filter.
But I think that is the only off the shelf base you can do that with. The rest you have to get the spin on kits from one of the members here.
Sorry I have no pictures I'm out of state. But their is a thread with it on here some where.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Why would you say that? The stock filter bases for the secondary and final filters are just bolted to the side of the block. Nothing special about them either.
gimpyrobb
27,785
749
Cincy Ohio
I'm pretty sure Westech posted a thread bout his filter replacement. Let me see if I can find it.
Looks like he deleted it when his "aunt flo" visited one time. Maybe a mod can bring it back.
Cleptomaniac
Tecumseh ,OK
Thanks Gimpy I will look in to it when I get home next week. If it is a matter of two filter bases and some fittings I'm all in! The primary was very easy to do and was very nessasary in my case cause my main was leaking. Someone broke the drain :( So it was on the top of the list.
Will the ones Jtonka sell are adapters not bases. I think they are great and will do them on my oil filters but I am the type that likes to walk in and buy something and walk out!
Not the best trait but.... I have always hated buying any thing on the net. This hobby has forced that so I'm getting a little better:?
4x4 Forever
Emerald Shellback
http://www.steelsoldiers.com/deuce/42523-another-spinon-primary-filter-install.html
You can get the base from NAPA or find one from WIX online. You will need to find the fittings for the fuel lines. It should not be too hard in a 'proper' hardware store, or you can get the kit at jatonkas
If you use Jatonkas kit, all ya gotta do is purchase filters after you do the mod.
I did the primary on my deuce, getting the base from NAPA. I'll be going to Jatonka for the Secondary filter setup.
ICAT
Idaho
lots of good info, thanks. I'm am suprised that no one as found a of the shelf secendary fuel filter system.
