Aftermarket gauges
Niuhi
23
Shoreline WA
Has anyone on here switched out their gauges for an aftermarket like Autometer or VDO. I'm curious as to how they were wired. Did you make adapters and use original harness or did you bypass the factory and rewire. I'm really not sold on the originals, plus I'd like to add some like boost, trans temp and tach.
Ronmar
6,632
Port angeles wa
The gauges used are off the shelf. They used a pigtail to interface the gauge threaded terminals to the plug-in gauge connectors on the harness. If replacing, you should be able to re-use the pigtails. Any new electrical gauges will of course need to be interfaced to power and their sensors and wiring added.
Always been a fan of mechanical gauges for their simplicity. I have contemplated shifting a few back to mechanical like oil pressure and air pressure, and adding boost and base fuel pressure. Then replace the voltmeter with a digital and configure it to read 12 and 24v busses... would probably replace fuel and temp with matching electrical...
Niuhi
23
Shoreline WA
I was thinking the same thing. I also agree with preferring the mechanical as I've always liked the full sweep of the dial on mechanical. I currently use Autometer in my 1 ton and have used them in miscellaneous Mopars, but unfortunatly they aren't going to have some of the gauges. I don't think they have the 24 volt or brake air guage, but still looking. Raneystruckparts.com has a nice selection of tractor gauges, but of course I have a particular Autometer I like, may just have to have an odd make or two.
